Room Tag Width x Depth Parameters generating question mark
rstewartbkddc
Message 1 of 42
rstewartbkddc
At the following Revit support link there are instructions on how to use calculated values to set up the room tag to publish the calculated width and depth of a room based on the room's perimeter and area: Revit 2017: How to create Room tag including Width x Depth parameters.  However, if the room is square and has width and depth values in the range of 11'-11 7/8" x 11'-11 7/8" up to 12'-11 3/4" x 12'-11 3/4" it will generate a question mark.  Any suggestions on how to resolve this dilemma.  Thanks!
Replies (41)
Message 2 of 42
cbcarch
As a quick test:
Try changing Project Units-Length Format-Rounding and Area Rounding--
Does Tag report dimensions?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 42
rstewartbkddc
Thank you for your response.  I have tried to change the unit rounding to different options in both the project file and the room tag file but with no better result.  Any other ideas?
Message 4 of 42
rstewartbkddc
I am finding that it occurs with other square dimensions even outside of the 11 - 12' range.  I had previously set this calculated value with a roundup formula, and it worked fine but it would only give whole number output.  I was wanting to get the full feet and fractional inches readout rounded to the nearest inch.
Message 5 of 42
Use the formula below for Room Length:
if(Area = (Perimeter / 4) ^ 2, Perimeter / 4, ((Perimeter / 2) - sqrt((Perimeter / 2) ^ 2 - 4 * Area)) / 2)
Message 6 of 42
rstewartbkddc
Thank you!  Works like a charm.
Message 7 of 42
Very helpful, thank you.
My floor plan displays the smallest length by the largest length, which causes inconsistency throughout the floor plan. Sometimes display length x width, other times width by length.
Do you know if there a way to get around this?
Message 8 of 42
does anyone know how to create the room tag to display width and depth, i tried clicking on the link and the site cant be found
Message 9 of 42
See post 5.
Message 10 of 42
Yes I saw that but I don’t get it. Where do I put that information in? Do I make a parameter of area? Why wouldn’t it be length?
Message 11 of 42
How do I begin?  Where do I begin?  The link does not work, so i do not know how to even start
Message 12 of 42
ml
I know this is an old topic but I was having similar frustrations attempting to schedule the width and length of the longest part of a room.
In case its of help i had created a dimension family which will report the width and length of a room and display in a schedule. This was the only way i could figure out how to solve this issue as you can easily schedule a component within revit.
Its a dynamic family which allows you to drag the points to the face of the walls with the dimensions reporting the length of each line.
The family is set as a specialty equipment though this can be changed.
you then set up a specialty equipment schedule to report the dimensions family within the room and room area.
Hopefully that's helpful for someone or provides a starting point for your own set up.
Cheers
Mark
Message 13 of 42
bnutkins
Observer
Observer
Sorry if this seems dumb but where do you type the "if" statement? i am trying to create a room tag as you have shown.
Message 14 of 42
Only if you use Revit 2017 or newer -edit or add a label in the Tag family, add a Calculated value label from the button with # symbol, and type the formula in the formula box of that label.
Message 15 of 42
Dear sir,
i have seen the formula you have given and i dont know how to apply this and where in which settings .
Message 16 of 42
Read the post above yours. It tells you where to use the formula.
Message 17 of 42
jeromemaceachern3284
Open--> Family--> Locate Room tags in annotations folder.
Create tab, click Label. click Fx (formula) button. Call the Value Length, change type to length and enter the formula
Hit ok.
Now click Fx (formula) button again . Call the Value Width, change type to length and enter the formula
Area / Length
Hit ok.
You can add a "x" for the prefix in the width line.
Hit Ok. Save Tag family and Load it into your project.
Message 18 of 42
Where do you find the "Fx" button please?
Message 19 of 42
What version you are using?
Add or edit a label of the Room tag and you will see the fx button to add a calculated parameter.
Message 20 of 42
BGTREKER
Observer
Observer
Thanks for the fine explanation!
Is there a way to limit dimensions to whole inches?
77' - 6" vs. 77' - 6 153/256"
Thanks in advance!
