Message 1 of 40
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
At the following Revit support link there are instructions on how to use calculated values to set up the room tag to publish the calculated width and depth of a room based on the room's perimeter and area: Revit 2017: How to create Room tag including Width x Depth parameters. However, if the room is square and has width and depth values in the range of 11'-11 7/8" x 11'-11 7/8" up to 12'-11 3/4" x 12'-11 3/4" it will generate a question mark. Any suggestions on how to resolve this dilemma. Thanks!
