Room tag problem m2
10 REPLIES 10
Message 1 of 11
2012 Views, 10 Replies
Room tag problem m2
Hello, my area label in room tag is not displaying correctly. It should be "m2" bu it displayes "m,". See attached picture.
Thank you in advance!
10 REPLIES 10
Message 2 of 11
Sahay_R
No picture. Take another look at the label in the tag. Also can you share the tag family?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 11
Sahay_R
Is this tag in 2018? I only have 2017!
This seems to be a rework of the OOTB family.
Take a look at this family and let me know if it works.
Rina Sahay
Message 4 of 11
in reply to: Sahay_R
The issue remains the same, I think that it is not an issue of the family. I tried several tag families and meters square doesn't display correctly in any of them.
Message 5 of 11
Sahay_R
It works correctly in my project. Makes me wish that I could take a look at what's going on with your project. Any way you could replicate this in 2017 so that I could take a look at it?
Rina Sahay
Message 6 of 11
It looks like the family you attached uses project settings. Make sure in you project settings the unit symbol is selected. Or open the family file and edit the label settings, uncheck the use project settings box and create your own settings for the family file
Message 7 of 11
The units for the area project settings are correct.
I can not find settings in the label which would use the project settings.  Could you please specify where to find?
I am afraid that it is a sort of system glitch.
Message 8 of 11
Unfortunately I dont believe it is possible to save project in to lower version of the Revit.
Message 9 of 11
semko_dm
HI, Andrey!
It's well known Revit 18 problem. It appears if you're using Windows in the Russian language no matter what language used in Revit. Autodesk support already aware about the issue, and we still waiting for the update.
If you can read Russian, u can find prove in this article
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Message 10 of 11
in reply to: semko_dm
I don¨t think that It would be the problem since I use the English windows. Anyway thank you for the link.
Message 11 of 11
VinnieM8SHEB
You could try a different font. Had a similar problem when I changed to a different font. May be something to do with certain fonts not allowing superscript.
Forma Design Contest
