room tag import
8 REPLIES 8
Message 1 of 9
2516 Views, 8 Replies
room tag import
how do i use (copy/paste or import) the room tag in the sample residential project in my new project?
novice
8 REPLIES 8
Message 2 of 9
ennujozlagam
try open them together copy and paste into new project or go to manage > transfer project standards select only you need. thanks
Message 3 of 9
in reply to: ennujozlagam
Thanks but the the text isn't displayed.
Message 4 of 9
ennujozlagam
click the room name and check properties setting or share some portion here so we can check. thanks
Message 5 of 9
ennujozlagam
sorry not possible, if you copy the whole text with area and paste into new file, yes the text will be missing, you need to go architecture > tag room > change you text setting. thanks
Message 6 of 9
attached is a screenshot of the tag i want changed.
is it also possible to add a hatch pattern within the tag?
Message 7 of 9
ennujozlagam
the easiest way is to create a color scheme. thanks
Message 8 of 9
ennujozlagam
room tag with hatching.
Message 9 of 9
Thanks very much for that, works well with the furniture on top.
Forma Design Contest
