how do i use (copy/paste or import) the room tag in the sample residential project in my new project?
novice
try open them together copy and paste into new project or go to manage > transfer project standards select only you need. thanks
click the room name and check properties setting or share some portion here so we can check. thanks
sorry not possible, if you copy the whole text with area and paste into new file, yes the text will be missing, you need to go architecture > tag room > change you text setting. thanks
attached is a screenshot of the tag i want changed.
is it also possible to add a hatch pattern within the tag?
the easiest way is to create a color scheme. thanks
room tag with hatching.
