room on 2 level
room on 2 level
Yien_Chao
Advisor Advisor
Message 1 of 23
room on 2 level
Yien_Chao
hello
I have an example of a staircase that turns 90 degrees between levels. however, I would like the room to be in both volumes. I tried with a volume room calculation, but it only works partially. do you have a suggestion?
thks
Replies (22)
Message 2 of 23
GustavoUbriaco
Hi!
change the upper limit to the desired level
If havent a lower level change the base offset
Gustavo Ubriaco Contreras
Message 3 of 23
Yien_Chao
Message 4 of 23
Message 5 of 23
Place the room on level 2 and drag the bottom grip down to level 1.
Message 6 of 23
GustavoUbriaco
Ok
this happens your room is placed in lower level place on the level 2 an add base offset.
You're doing like this
Message 7 of 23
Yien_Chao
i did exactly this.. but no success.
it always works partially.
Message 8 of 23
GustavoUbriaco
walls make this a little bit hard but if you play with floor elevations levels and walls could works
Message 9 of 23
Did you activate VOLUME Calculations?
Message 10 of 23
Yien_Chao
yes! and the build is the same.
Message 11 of 23
Post the file.
Message 12 of 23
Yien_Chao
Message 13 of 23
Seems to work here.  Area and Volume.
Message 14 of 23
Scratch that, @Yien_Chao. I see what you are trying to do now.  Don't think you can get there with 1 room.
Message 15 of 23
Yien_Chao
thank you for trying
Message 16 of 23
GustavoUbriaco
With analytical spaces will works.
or if I were you I'd create a mass to get that volume information
Message 17 of 23
Yien_Chao
i see.. bice try but we need it to be room.
Message 18 of 23
You want it to be Room because you need the color in a color scheme on both levels or because you need the Volume?
Message 19 of 23
Yien_Chao
Need it for volume calculation and tag on plan.
Think i will just duplicate the room then.
Message 20 of 23
Normally a Space volume is used for HVAC calculation, not sure what would a Room volume can be used for.
For tagging, create two rooms with identical data (name, number, etc...), one on each level.  You can group the room schedule by number un untick itemize box so the two rooms shown as one row.  Set the Volume field to Calculate Totals to get the overall volume.
