AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
What is wrong with my walls?
5 ANTWORTEN 5
Nachricht 1 von 6
jona267j
274 Aufrufe, 5 Antworten
It seems like there is something on top of my walls.. Can't figure it out how to remove it, or what it is :trauriges,_aber_erleichtertes_Gesicht:SkƦrmbillede 2022-06-06 162149.png
5 ANTWORTEN 5
Nachricht 2 von 6
jona267j
als Antwort auf: jona267j
SkƦrmbillede 2022-06-06 162732.pngwall properties
Nachricht 3 von 6
Got an In-Built Sweep atop the Wall?  Post a screenshot of the Wall's Edit Assembly Dialog w/ Section Preview active.
Or, maybe it's an Embedded Wall condition? In other words, two Walls atop one another.
Or, is it two Walls in two different Phases and "Show All" is the View Phase Filter?
...Post the file and we'll tell you precisely what is going on, instead of guessing.
Nachricht 4 von 6
jona267j
als Antwort auf: barthbradley
Nachricht 5 von 6
jona267j
It's not a problem when I use the generic walls..
Nachricht 6 von 6
Lachlan-JWP
Can you show the wall properties with the section preview turned on?
That will show if you have any sweeps built in to the wall type.
In Foren verƶffentlichen
