Room marking colors visible through floors
So, I have an issue I dont know how to deal with.
I've made floor plans with coloring for two floors of my house. The problem is, some of the colors from the first floor are visible on the second floor. I dont know whats causing this.
I'm attaching the file if anyone wants to take a look! The room markings are on the "1. Etg (1)" and "2. Etg (2)" floor plans
Any help appreciated 🙂
ennujozlagam
Hello, try to go properties in your second floor check set your underlay to none. And try to untick your hardware acceleration from options. Thanks
Hi!
Thanks for replying.
As far as I can see, underlay is turned off.
Hardware accelleration is also turned off - Revit crashed every other minute when it was enabled 🙂
Dont forget to set your room height to the proper dimensions of your levels.
Because now your limited offset of your room is 4000mm instead of 2700mm
Thats why you see your other rooms as well.
Kind Regards,
Job van Hardeveld
Cadac Group AEC
Room's Limit Offset!
Thank you so much! Looks good now.
