Split Faces using api
1 ANTWORT 1
Nachricht 1 von 2
ratno123s
410 Aufrufe, 1 Antwort
How to split a face of a wall in to two (given the curve or points defining the boundary or area) using api.
aim is to achieve functionality similar to Split Face tool in revit through api
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: ratno123s
Hi @ratno123s
The Revit API forum can be found on the following link https://forums.autodesk.com/t5/revit-api-forum/bd-p/160
PS: Kindly do not cross post the same question on various boards of this forum...please follow up on the same question posted on Revit API https://forums.autodesk.com/t5/revit-api-forum/split-face-using-api/td-p/6624321
