Room finish
Room finish
Room finish
Hey.
I can't figure out what base finish is, in rooms propertise.
I know what floor wall and ceiling finish means. Smiley Happy
But cant figure out what base is, any help?? Smiley Very Happy
cbcarch
It means the wall base--vinyl, wood, etc. at the bottom of the wall where it meets the floor.
It is typically applied as a sweep--either "built-in" to the wall type, or manually applied as a sweep.
The Material and Profile can be set for the type of base you are using.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
I don't get it.
If you see the picture there is the list from revit.
Can you send a picture of what it is? Smiley Happy
cbcarch
see attached picture
Cliff B. Collins
Thank you very much. Smiley Very Happy
Kushnir.A
Baseboards. Base of wall.
Best regards, Alexey Kushnir. | Facebook
