All elements display in Red?
11 ANTWORTEN 11
Nachricht 1 von 12
dlafont6969
3925 Aufrufe, 11 Antworten
I'm using Revit Lt 2019. I'm quite experienced in using Revit and usually use my own template to start a project.
However when ever I use the Generic Architectural template to begin my model and go into a 3D view, goto Detail level Course, turn on section box and pull it down to cut the walls and doors etc. All elements cut display in Red? I have looked everwhere to fix the problem all the obvious places I've looked in materials, phases, over-rides, object styles... I just can't find out why? I can go into each element and change them individually or by category however it seems like there is a setting somewhere I'm missing.
It doesn't happen when I use my own template, only the Generic Architectural template.
Please see my picture attached.
Maybe you could test it yourself?
Thanks for your Help
Dean La Fontaine
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: dlafont6969
Are the cut elements new or existing?
Nachricht 3 von 12
aRcHiTeCt.JM
... hi @dlafont6969
... upload your model to take a look
... did you check visibility / graphics ?
.... object styles ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 4 von 12
cbcarch
-Is there a Filter applied setting the cut pattern to solid red?
-Check Wall Properties>Graphics>Coarse Scale Fill Color & Pattern
-Try changing the 3D View's Phase Filter to Previous & New ( it is set at Show All)
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 5 von 12
RDAOU
From my experience between Germany, US, and the MENA region, I have at one point or the other used a pre-set template from the autodesk content library. Those default templates have region specific visual settings and preset filters as well as customized tags that are commonly used in that region. EXAMPLE: cut walls setting in the German template behaves similar to the image u posted
You may readjust those settings of course but with some templates it can get quite tidious
Nachricht 6 von 12
dlafont6969
als Antwort auf: cbcarch
I tried all those things and no luck, Revit 2019 doesn't seem to have Filters
I've attached the model for you,
Thanks Dean
Nachricht 7 von 12
dlafont6969
als Antwort auf: aRcHiTeCt.JM
Thanks Dean
Nachricht 8 von 12
dlafont6969
als Antwort auf: ToanDN
Elements are new.
I tried all those potential solutions others posted and no luck, Revit 2019 doesn't seem to have Filters
Thanks Dean
Nachricht 9 von 12
cbcarch
Revit 2019 does have Filters.
VG>Filters
Cliff B. Collins
Nachricht 10 von 12
dlafont6969
I found my on solution.
See attached picture
Nachricht 11 von 12
cbcarch
See my reply #4 above.
Please accept as solution.
Cliff B. Collins
Nachricht 12 von 12
dlafont6969
I meant Revit LT 2019 doesn't have filters.
I've found my own solution.
