Room color not showing for one of the rooms
Marcus.Isacsson
Message 1 of 11
Marcus.Isacsson
Hi fellas!
I have a weird problem where the color doesn't show for one of the rooms.
It's the same level as the rest and it's also the same department but something makes it show as white instead of colored.
Any solutions to this weird problem?
Replies (10)
Message 2 of 11
ennujozlagam
@Marcus.Isacsson check your room separator/ room bounding. thanks
Message 3 of 11
Marcus.Isacsson
Here's how it looks for us. There's a bunch of room separation lines along the edges, what kind of problems can they create?
And where do the problems occur?
Message 4 of 11
ennujozlagam
@Marcus.Isacsson hello, just check with is there a room name for that room?.  i just did a trial test. thanks
Message 5 of 11
Marcus.Isacsson
Yes, there's a room name and department. Still white though.
Message 6 of 11
ennujozlagam
Hello, is there anyway you can share some part of the file so we can check, I will try tomorrow when I get back to office. Thanks
Message 8 of 11
Marcus.Isacsson
Hi fellas! Thanks for all the help, I fixed the problem yesterday. Was some room separator lines that messed it up.
Weird though that you can place a room that looses its color this way.
Message 9 of 11
trunyan
Found out that when the material of the floors, walls, anything in the view has a 'solid' face pattern, it will hide the color of the room fill.
1) you can change the material and erase the surface pattern 'solid'
2) You can choose the floor or wall that hides the room fill, choose: Override graphic view> by element> and make the surface patterns invisible for that view.
3) In visibility graphics you can turn off the pattern for floors in your template.
Hope this helps to solve the problem.
Message 10 of 11
harsh_sampat3JK69
Observer
Observer
I know this is old but for anybody new if there are overlapping room boundary, whether it is an overlapping column and wall which are both room bounding or room separators removing these will fix the issue, also i think if you have a plan region and its only covering a part of the area it tends to glitch out
Message 11 of 11
tdaviesHVRJJ
Thanks mate this worked for me
