Hi fellas!
I have a weird problem where the color doesn't show for one of the rooms.
It's the same level as the rest and it's also the same department but something makes it show as white instead of colored.
Any solutions to this weird problem?
Solved by ennujozlagam. Go to Solution.
@Marcus.Isacsson check your room separator/ room bounding. thanks
@ennujozlagam wrote:@Marcus.Isacsson check your room separator/ room bounding. thanks
Here's how it looks for us. There's a bunch of room separation lines along the edges, what kind of problems can they create?
And where do the problems occur?
@Marcus.Isacsson hello, just check with is there a room name for that room?. i just did a trial test. thanks
@ennujozlagam wrote:@Marcus.Isacsson hello, just check with is there a room name for that room?. i just did a trial test. thanks
Yes, there's a room name and department. Still white though.
Hi fellas! Thanks for all the help, I fixed the problem yesterday. Was some room separator lines that messed it up.
Weird though that you can place a room that looses its color this way.
Found out that when the material of the floors, walls, anything in the view has a 'solid' face pattern, it will hide the color of the room fill.
1) you can change the material and erase the surface pattern 'solid'
2) You can choose the floor or wall that hides the room fill, choose: Override graphic view> by element> and make the surface patterns invisible for that view.
3) In visibility graphics you can turn off the pattern for floors in your template.
Hope this helps to solve the problem.
