Room bounding issue
Room bounding issue
Room bounding issue
Hi!
Goal: Create rooms below and above stairs.
So far,
I have a created a model in place to act as a room bounding element (because stairs are not room bounding).
Place a room on ground level. Room is bounded by model in place.
Created an intermediary level to place room above stairs.
Problem:
After creating the room it seems to leak through the model in place.
Weird thing is, the leaking occurs at the intermediary level. So when I move the level to test, the room regenerates and leaks at the new level.
Any help?
Basam.Yousif
OK!
I made it work for you!
Two things:
  1. The "stair" was a ceiling - and I turned it into a "wall" and it seemed to work better!
  2. the room reference point seemed to be confused by the shape (and I don't blame it 🙂 ) but I tried to drag it in both the plan (level 2 worked better than level 1) and in the section view.
I recorded my fourth attempt - that worked and attached the model for your reference!
http://autode.sk/2ppNPPD
This was fun. Thank you!
Thanks for your attempt!
But what i need is the 1 room to be below stairs, and 1 room above stairs.
Example below with just a simple form (left).
Any suggestions?
Best
Basam.Yousif
Done!!
I actually did not know you could do this and now I do 🙂
Here is a screenshot and the model is attached, but I will not tell you how I did it yet, and see if you can figure it out. If not, then I will tell you tomorrow.
Hint: I added a new level - and for a reason!
I understand what you have done, nice moves.
I've accepted as solution. Thanks!!
Our example was simplified. With walls and floors involved, the conditions change and I am finding leaks more and more complicated to patch up.
Nice working with you.
Basam.Yousif
The pleasure is all mine 🙂
The secret to making this work is changing the computation height of the level (that is the elevation value where the room expands in all directions looking for bounding elements) I changed it for Level 3 to be HIGHER than the stair, and then I placed room 2 on it. Meanwhile, I left level 0 c.h. at 0 as is unchanged.
What other fun stuff do you have for me?
Thank you very much 🙂
