Linking dwg lines vs spot elevation
04:19 AM
I've got dwg file including only lines positioned in 3D space (variable Z).
When I link this *.dwg file to REVIT, I've noticed some behaviour:
1) I can put spot elevation - only to lines that ends are not touching end of another line
2) I can put spot elevation - When two lines are touching but have different linetype
I tried to change lines to polylines, 3D polylines, purge drawing (leaving only one linetype) but it allways behave the same...
Inserting small gaps between connecting lines or changing linetypes in every second line would take too much time.
Does anyone know why it behave like this and know some smart workaround or solution for my problem?
Thanks in Advance
