Room boundaries
Room boundaries
kherrman
Message 1 of 10
Room boundaries
kherrman
When I try to mark this one particular room, I get an error that it is outside of it's room. This is where the room shows when I direct it to move to the room.
Replies (9)
Message 2 of 10
Maybe it is not bound properly. Use Room Separator Lines to close the gaps between Room bounding elements.
...also turn on Room Interior Fill so you can see the extents of the room.
Message 3 of 10
If you have a finish floor that is higher than the level then select it and change to non room bounding.
Message 4 of 10
kherrman
I placed a room separator box in the center of the room and it does the same thing
Message 5 of 10
kherrman
That's what I initially thought it was, but I removed the finish floor and it still does it. I also went through and delated all of the room separators.
Message 6 of 10
View Range.
Message 7 of 10
kherrman
No different than any of the other rooms
Message 8 of 10
Maybe you have more than one floors that are higher than the level.  Reveal hidden elements to find out
Message 9 of 10
RDAOU
@kherrman
  1. Did you check phasing?
  2. or if Separator are on one level while Room being placed on a view view associated with another level?
  3. or if Separators and rooms are in the same/different design option?
Message 10 of 10
Lachlan-JWP
Are you tagging manually or as part of a "tag all" feature?
