Hi.
Does anyone know if its possible to deselect room bounding on individual elements in linked models?
Im currently working to take out room areas for energy calc. and i want my boundaries of my externatal walls to be exterior face and interior to be wall center.
my thoughts was a work around by using room seperation lines but i'm not able to as long as exterior walls are set as room bounding..
Any suggestions?
Hi.
Any suggestions?
Solved by L.Maas. Go to Solution.
Room bounding for linked files is set for the whole linked file, not for individual elements in that linked file. You would need to open and modify the elements inside the linked files for this
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
yea that's what i was affraid of..
I have access to the linked model, but if i untoggle the room bounding of the exterior walls i will destroy the room bounding of the Ark rooms...
Guess there is only the hard way around it by using seperation lines...
Thanks for your reply
