Solved by PijPiwo. Go to Solution.
Yes, create a rectangular mass block extrusion with the footprint of your roof, then create a void extrusion with a shape highlighted in blue (see pic.), repeat for the other two roof planes and apply roof by face.
Alternatively, if you’re not comfortable with the massing environment, make a regular roof by footprint and create a sweep for the curved part of the roof - two pairs for two different slopes and cut the excess at the ends with a void extrusion.
Fascia tool will work as well instead of a sweep - two fascia sets with a profile of the angled roof part, you will still need to cut the excess at ends.
