Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
I see that you are visiting as a new member. Welcome to the Autodesk Community! ![]()
Can you try changing your master units to mm in Revit and export the IFC file again? Let us know if there is an improvement to your graphics.
Before linking an IFC file, click ![]()
Open
(IFC Options) and use the Import IFC Options dialog to do the following:
Open
(IFC ) The Open Dialog offers some options which can help handle IFC Files in Revit:
AutoJoin Elements will attempt to join Walls and other elements like it is automatically happening when modelling in Revit. However, this option can sometimes lead to errors or corrupted geometry. In this case, this option can be unchecked, which will ignore all Joints.
Correct lines that are slightly off axis is an option familiar from the CAD Link / Import option and basically does the same. It can be left checked, unless the project has some elements which are slightly off axis on purpose.
Let us know if you are able to resolve your issue.We are glad to help!
Please mark this response as "Accept as Solution" if it answers your question to help others seeking similar solutions. Kudos gladly accepted.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
