Roofing
Roofing
zs-17
Message 1 of 44
Roofing
zs-17
Hello
I looked for another solution to my roof problem, I found a Revit roof modeling file I would like to add it (attachment file). So basically I have 2 questions:
  1. How to replace the generic existing with this model type? I opened it in my file and tried the Match Type Properties. I also saved the file as Family file. I didn't know how to put it in my file.
  2. How to model it in my file if I don't have a previous roof?
Note: If I have to send these 2 questions in separated  conversation, please let know, for later conversation.
Regards
Replies (43)
Message 2 of 44
Transfer Project Standards.
Open both files: this file and you working file.  Go to your working file and go to Manage>Transfer Project Standards: check only the Roof Types box.
Message 3 of 44
zs-17
Hi
  1. I still can't find. Where to locate it please?
  2. Just to understand how Revit works. Why to transfer my working file if I want to put this file in my working file.
  3. In case I find it. Do I have to sketch a new roof or I can replace the existing?
Many thanks
Message 4 of 44
Okay I thought you only needed to get the Roof type, not the actual model. To bring this model into your file, go Insert menu > Load as Group, then select the file and okay to bring it in.
Message 5 of 44
zs-17
I would like to apologize if I mislead you. I'm new to Revit so I don't know the right words and expressions to the right question. I guaranty that I'm not trying to be rude. And the bad news is I still can't find. I'm sorry. In a simple way, I want to sketch this type or roof tile in my project. How to do it please?
Many thanks
Message 6 of 44
I see the file you attached now.  See screencast in a few minutes.
https://knowledge.autodesk.com/community/screencast/e9cf3cd5-9872-414e-ac66-5a160a034dff
Message 7 of 44
zs-17
It works only on a roof with 4 points. I have sides with less and more than 4. Is there a way to do it?
Message 8 of 44
For 3 sides, place the family with 3 points aligned and one point off so it is still a triangle.
For more than 4 sides, place it several times.
Message 9 of 44
zs-17
I tried below 2 scenarios with success. ( point 3 and 4 in second photo are next to each others and not on top of each others.
Message 10 of 44
You must be picking the wrong points.  See below.  I would change the view to Hidden instead of Shaded or Realistic when doing this task.
Message 11 of 44
zs-17
Yes I did this mistake. I still have the challenge to do it with more than 4 points.
Message 12 of 44
Like this?
Message 13 of 44
zs-17
In this condition 3 models should be created next to each others. But I can't remove the cut line in between
Message 14 of 44
You could create a mass based on the roof, divide surface, and load the tile as a generic model pattern based and it will populate the entire surface automatically.  Share your roof model I can show you.
Message 15 of 44
zs-17
I attached the file
Message 16 of 44
@zs-17 :  Just want to say that you have no need to apologize. You come across as quite respectful to me.  Sometimes miscommunications happen. No biggie.
Welcome to the forum.
Message 17 of 44
@zs-17 wrote:
I attached the file
See the revised file and a screencast in a few minutes.
https://knowledge.autodesk.com/community/screencast/56c13b55-dddf-45f8-a422-4b77afbdd7d1
Screencast will be displayed here after you click Post.
Message 18 of 44
zs-17
Hi
I clicked on Reference line then without do draw a line I click on Set Work Plane then Line and I start to draw my lines. But I don't what I miss to get this below error message
Message 19 of 44
Sorry. Before start the Mass, go to Mass & Site tab, click the Show Mass... button drop-down (2nd from the left on the ribbon), and choose Show Mass Form and Floors.
To recap:
- Enable view of Mass following the step above
- Start an in place Mass
- Set the workplane to a roof surface where you want to place the tile
- draw a closed loop Reference lines following the roof surface boundary
- select the closed loop reference lines and create form, choose 3d form, not 2d face
- grip edit the form so that the intended face is on top
- select that face and create divided surface
- change U and V to distances to match the family (39 cm and 24.5 cm)
- select the divided surface and change it to the correct roof tile from the type selection
- finish the mass
It sounds like a lot of steps but if you watch the screencast, it takes just over 1 minute.
Message 20 of 44
zs-17
It's already set to Show Mass Form and Floors
