A chimney structure cutting through a pitched roof. Lines missing from the views. I've tried a number of things including, cutting a shaft through the roof, creating an opening in the roof, joining and cutting the elements, changing course, detail views etc..... the red lines marked here seem to be invisible!!!!!
Why would this be happening? Any ideas would be much appreciated
Solved by barthbradley. Go to Solution.
try to change setting of your detail level and visual styles and see if helps. thanks
Just draw it in the sketch, no slopes defined, you can use pick lines on the chimney edges.
I'm not clear why the opening edges are not showing if you placed a shaft through the Roof like you said you did. Also, have you tried using the Join Geometry tool to joint the two geometries together?
Hi @ADT267,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. 🙂
Thanks, your sketch was enough to show my problem (stupidity). I forgot to set the base/height of the cut. Doh!!!!
There's an old saying.... cant see the woods for the trees!!! So busy trying to set view settings, never thought to check the actual cut.
