Schedule Shared Parameter of Doors in Linked Models
BenoitE&A
BenoitE&A
I haven't found a clear answer so here is my question :
I have a host file with 2 linked files.
Nothing in the host (templates and annotation families)
Some doors and walls in model 1 (structure model)
The other doors and all the Rooms in model 2
I want to create a schedule based on a common Shared Parameter (common to the 3 files, based on the same SharedParameterFile).
Is it doable?
All my tries ended with an empty schedule.
Thanks by advance
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Karambaki
If I understood you right. You have a host, and links containing Families that have shared parameters, and those parameters are not appearing in the schedule when trying to create it in the Host file ?
If so, then you need to have that shared parameter existed in the host file it self, either by adding it as a project parameter.
or by loading a family containing that same parameter.
And while creating the schedule, there's a button called "Include Elements in Link", I expect you know that already.
We sometime create junk families that contain shared parameters for an easy management in such cases.
I hope this could help.
Karam Baki
Architect, Revit Guru, ACI
Facebook | Students' Work | LinkedIn
E-Mail : karam@aecedx.com
Should be doable. Did you check "include linked elements" in the Schedule?
BenoitE&A
Ok thank you both.
I was modifying the ID of the parameter (in linked file it was different from host file).
Looks like you need the same ID in all files.
Now it works.
Benoit FAVRE
