I haven't found a clear answer so here is my question :
I have a host file with 2 linked files.
Nothing in the host (templates and annotation families)
Some doors and walls in model 1 (structure model)
The other doors and all the Rooms in model 2
I want to create a schedule based on a common Shared Parameter (common to the 3 files, based on the same SharedParameterFile).
Is it doable?
All my tries ended with an empty schedule.
Thanks by advance
Solved by BenoitE&A. Go to Solution.
If I understood you right. You have a host, and links containing Families that have shared parameters, and those parameters are not appearing in the schedule when trying to create it in the Host file ?
If so, then you need to have that shared parameter existed in the host file it self, either by adding it as a project parameter.
or by loading a family containing that same parameter.
And while creating the schedule, there's a button called "Include Elements in Link", I expect you know that already.
We sometime create junk families that contain shared parameters for an easy management in such cases.
I hope this could help.
Should be doable. Did you check "include linked elements" in the Schedule?
Ok thank you both.
I was modifying the ID of the parameter (in linked file it was different from host file).
Looks like you need the same ID in all files.
Now it works.
