Roof pattern not showing up in RCP
Message 1 of 9
I have two separate roof models in my revit file.
In the RCP, the roof pattern for one roof is showing up, but the other one isn't.
They both have same material.
Please see the attachment. Does anyone know why this is happening?
Replies (8)
Message 2 of 9
Are they at different levels?  It could be a view range issue.
Message 3 of 9
hmunsell
how about a Section/Elevation view?
also, why do you want to show the "Roof" pattern in a Reflected Ceiling Plan (RCP)?
Howard Munsell
Message 4 of 9
That does look odd to me.  You we certain that they are both using the exact same surface pattern?  If so, can you post the file?
Message 5 of 9
I found the issue. I accidentally hid the roof element.  😅
i couldn't tell the roof was hidden because it was RCP.
Message 6 of 9
Message 7 of 9
hmunsell
LOL, been there-Done that...
still curious though, why do you want to show the "Roof" pattern in a Reflected Ceiling Plan (RCP)?
Howard Munsell
Message 8 of 9
what I meant by "roof" pattern is the pattern on the underside of my roof eave. In the RCP, I'm indicating what material I'm using for the roof eaves.
Message 9 of 9
hmunsell
Ohhhhh... that makes sense. 🙂
Howard Munsell
