"Can't create" error message for beams
I'm trying to make a hip and valley beams for my roof.
I'm using "Structure > Beam > pick line" method.
I have "3d Snapping" checked off.
But I get an error message saying "can't create."
Does anyone know how I can fix this?
I found the solution to my own problem.
Just putting the answer out there so that someone struggling with the same error message find a solution.
Step #1:
Structure> Work Plane> Set (Work Plane) > Specific a new Work Plane > Select "Name" > then choose a level (I chose 'Top of Plate' level for my model)
Step #2:
Structure > Beam> Make sure '3d snapping' is checked off
It should work after doing the steps above.
