Project parameter
8 ANTWORTEN 8
Nachricht 1 von 9
XXalessio.amodioXX
405 Aufrufe, 8 Antworten
Project parameter
Hi all,
I wonder if there is a way to add a project parameter to a certain family instead of whole category (e.g. Generic model)
8 ANTWORTEN 8
Nachricht 2 von 9
Rafal.Gaweda
als Antwort auf: XXalessio.amodioXX
Nachricht 3 von 9
I think you're looking to use shared parameters? Mentioned in the link above also, but a bit more the direction you're looking for maybe. Is it for scheduling?
Nachricht 4 von 9
It is for Dynamo coding but in forum They told me not possible
Nachricht 5 von 9
Still unclear what you're trying to do, perhaps if you elaborate some more. But I suppose if on a Dynamo forum it is said to be impossible, then I guess it most likely is...
Nachricht 6 von 9
hmunsell
the point of a Project Parameter is to apply the parameter to the whole projector based on Category. why not just make a Generic Model with a Shared Parameter in it instead of a Project Parameter, like @martijn_pater suggests
Howard Munsell
Nachricht 7 von 9
XXalessio.amodioXX
als Antwort auf: hmunsell
Using Shared parameter is an Idea, but for dyanamo coding it was not working.
Nevermind
Nachricht 8 von 9
I'm not that advanced with Dynamo, but I think you could perhaps use Element.SetParameterByName node to set some shared parameter value(s)...
Nachricht 9 von 9
bin
You can just use Family Parameter for Dynamo.
