Ribbon blinking in Revit 2017, 2018 and 2019 - Windows 10
rmoore1
Message 1 of 18
rmoore1
This ribbon blinking happens if I let Revit sit for an hour or so. If I work continuously in Revit this does not happen. Does this in 2017, 2018 and 2019. Hardware acceleration on or off does not affect this blinking. The video card is GeForce GTX 1080 running latest driver. I've tried older drivers and it also does not change this behavior. Revit is the only program this occurs in. I have re-installed Windows 10 to no avail.
Screencast will be displayed here after you click Post.
1d3bb4a2-dda2-4816-8a5b-983a90325c31
Replies (17)
Message 2 of 18
Viveka_CD
Hi @rmoore1
Sorry to hear that you are facing issues.
  • Does this issue begin to occur after a specific windows update or with a specific model/ user configuration?
  • Are you using Revit on a high-resolution monitor (3K or 4K)?
Some points to try:
Let me know if this helps resolve your issue.
I look forward to your reply update.
Message 3 of 18
rmoore1
I think it happened after the last Feature update but I couldn't roll that back. When I reinstalled the OS it updated to the latest Feature update and would not let me roll it back. I do not have a high-res monitor or change the desktop scaling. I have reset the UIState and will let it sit while I'm at lunch
Message 4 of 18
rmoore1
It was blinking when I came back from lunch. BTW, what happened to my screencast of the blinking?
Message 5 of 18
Viveka_CD
OK @rmoore1
Let me know your graphics card configuration. Could be that the graphics card is not supported or you'll have to roll back your driver.
Message 6 of 18
rmoore1
That info is in the first post
Message 7 of 18
Viveka_CD
@rmoore1
Sure, can you roll back the driver for GeForce GTX 1080 and let me know if there is any difference.
Message 8 of 18
rmoore1
I said I tried older drivers and it didn't make a difference
Message 9 of 18
Viveka_CD
Hmm... OK
Can you send across a journal file to investigate further.
Message 10 of 18
I recall an Revit implementation company coming up with new features to remind people to save their model...
Are you by chance working with another company that is providing add-ins for yours?
Message 11 of 18
rmoore1
By blinking the ribbon at you? That's hilarious! No, we are not doing that...
Message 12 of 18
One of the other options in that add-in was the ribbon changes to red if you are working in the Central model.  So that is why I thought the blinking might be a feature of that add-in too.
Message 13 of 18
rmoore1
Here's a journal file from when I got back from lunch
Message 14 of 18
Viveka_CD
Hi @rmoore1
Thanks for sharing your journal, while I'm parsing it -
Can you disable the P&ID modeler and try launching Revit again and see if this helps?
Also, can you check if HA is on
  1. Go to the Revit Menu/ Options/ Graphics and make sure that the Hardware Acceleration is on
Message 15 of 18
rmoore1
Never heard of the P&ID modeler, and I said previously HA on or off doesn't affect this
Message 16 of 18
Viveka_CD
Hi @rmoore1
Your journal file indicates the P&ID modeler.
Can you test the below for me?
Please try disabling the add-ins and let me know if there is an improvement in performance.
If you want to test Revit with all add-ins disabled [or selectively disable add-ins] follow the steps below:
1.  Close Revit.
2.  Locate the following folder:
    C:\ProgramData\Autodesk\Revit\Addins\[Version]
3.  Temporarily move the add-in files from the folder above to another location.
4.  Launch Revit; add-ins will be disabled.
Alternate locations that add-ins could be loaded from:
C:\ProgramData\Autodesk\ApplicationPlugins          (This location can be used for add-ins that span multiple products/versions.)
C:\Program Files\Autodesk\Revit [Version]\AddIns   (This location is generally used for Internal Add-ins, but some older add-ins may still try to load into this location.)
Looking forward to your reply update.
Message 17 of 18
rmoore1
I found the P&ID Modeler addin in the internal folder and moved it. Came back from a more than 1 hour lunch and no blinking! How did you know about it? Has there been problems with this addin? And why only my machine?
Message 18 of 18
Viveka_CD
Hi @rmoore1
I'm glad to hear that there is no more blinking!
Hope the Friday lunch was great as wellSmiley Happy
Yes, some 3rd party add-ins have caused performance issues.
Not sure why it happens in your specific machine, but if you need me to test further, please send me an NFO file and I can share a collector utility with you to extract files for diagnosis. (share through a private link)
