RFA to RVT conversion using Design automation api
harishogguharis
harishogguharis
 My requirement is to perform the conversion programmatically using the Design Automation API.
To achieve this, I am following the approach outlined in this guide: https://github.com/autodesk-platform-services/aps-tutorial-postman/blob/master/DA4Revit/instructions....
Unfortunately, I am encountering an issue while running the WorkItem. I am able to obtain the WorkItem ID, but the process subsequently fails. The error report and appbundle.zip is attached for your review.
Here's a summary of the steps I've followed:
Step Purpose
1Get Forge Access Token (OAuth2 client credentials)
2Set app nickname (only once)
3Create & upload AppBundle (with your Revit add-in DLL)
4Create Activity (executes the DLL inside Revit)
5Upload .rfa to OSS
6Run WorkItem (RFA in → RVT out)
7Download result from OSS
Could you please assist me in identifying the cause of this failure?
SA3816
Community Visitor
Community Visitor
good day haris! pls were you able to fix the rfa to rvt error!?
