Lines not showing up
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
steadfasthomeplans
2327 Aufrufe, 2 Antworten
On one of my floors the lines aren't showing up.
In the visibility graphics all the lines are checked. What else do I need to do to see the lines, its only in this level that I can't see the lines, they work on the other levels.
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: steadfasthomeplans
Here are several suggestion
1. Check if the line is placed in workset that is not visible
2. Check if the line is drawn at lower than the view range. Set the view range depth to unlimited
3. Check if the crop view is hiding those lines
Nachricht 3 von 3
steadfasthomeplans
als Antwort auf: syman2000
It was the view range, thanks!!
