How to control an angled scope box view orientation on a sheet?
hliS658H
hliS658H
1. I need to make an enlarged view of a part of the building and put into another sheet. This part of the building is 45 angled, I created a scope box   following the angle as you can see in the image labeled as 1. when I open the view, it is displayed in portrait (image 2), but I need it to be landscape (image 3). Is there a way to make this happen? If this impossible, then I have question 2
2. I rotate the viewport, but the view title rotates as well, how can I keep the view title horizontal?
RLY_15
Rotate the scope box 90 degrees, then adjust the extents to fit the boundary correctly.
SteveKStafford
Keep in mind that rotating a view's crop boundary or a scope box needs to be in the opposite direction you want the building to rotate. If you're building's wing is at 45 degrees where 0 is to the right and 90 is straight up, and you want the wing to be horizontally aligned with the sheet by rotating the building 45 degress clockwise, the boundary needs to rotate 45 degrees counter-clockwise.
If you sketch a orthogonal scope box around your angled wing, then rotate the scope box 45 degrees counter-clockwise, you will find the view will "rotate" the building clockwise when you assign the scope box to the view.
Steve Stafford
mari.shimode
Hi @hliS658H, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
mari.shimode
Hi @hliS658H, as the community found @SteveKStafford's reply useful, I have marked it as an accepted solution so others who have the same question can refer to it.
If you're still having the issue or have any other questions related to what you originally asked, please create a new topic with a link to this post included so the community can follow the conversation easily.
Mari Shimode
