Revit Worksets
6 REPLIES 6
jszymborska
385 Views, 6 Replies
Revit Worksets
Hi there, I'm trying to figure out how to move dimensions to a separate workset. Is it possible?
6 REPLIES 6
RSomppi
in reply to: jszymborska
Why?
jszymborska
in reply to: RSomppi
Because I was asked to do so.. Just wonder if it's possible?
Dimensions are not model elements. Therefore they pertain to the view where they are created. They have a workset property that is grayed out, which is the name of the view. If you don´t want to see them, just hide the category.
RSomppi
There has to be a reason for it.
The simple answer is no. They cannot be assigned to a workset. If you tell us why you need it, there may be another solution.
I think it will be better if you'll create a View Template without dimensions....and then apply it to desired Views
Constantin Stroescu
jszymborska
I was just looking for a straight answer (yes or no), couldn't see one anywhere. So thank you for this.
I have another solution, just made new vie template and turned their visibility off. I had to hide them for a submission and my manager asked if I can put them on new workset.
Forma Design Contest
