Hi there, I'm trying to figure out how to move dimensions to a separate workset. Is it possible?
Solved by constantin.stroescu. Go to Solution.
Solved by RSomppi. Go to Solution.
Solved by Alfredo_Medina. Go to Solution.
@jszymborska wrote:Hi there, I'm trying to figure out how to move dimensions to a separate workset.
Why?
Dimensions are not model elements. Therefore they pertain to the view where they are created. They have a workset property that is grayed out, which is the name of the view. If you donĀ“t want to see them, just hide the category.
There has to be a reason for it.
The simple answer is no. They cannot be assigned to a workset. If you tell us why you need it, there may be another solution.
I think it will be better if you'll create a View Template without dimensions....and then apply it to desired Views
Constantin Stroescu
