1. Being able to select a Model Hatch in a wall cut Pattern. This would make it so we can add batt insulation inside a wall type.
2. Being able to modify the crop region of drafting views.
Not sure where else to post this, but these changed would make productivity so much simpler and faster.
Solved by ToanDN. Go to Solution.
You really want every wall section view in your Project to show squiggly Batt Insulation? Been there, done that, hated it. Save that LOD for Details.
For the time being, you can draft in a model view and you can crop.
