Good afternoon dear Revit Mentors:
I created a component, Model-in Place for a pool & Deck and when I draw a section like this:
-it shows like this: elements (like the stairs) behind the line of view range are showing up. I do not want to see these stairs... I want to show what is under the deck.
I don't know if I have to make an additional settings on my Model-in Place so that the section can produce the view correctly.
Any suggestions please?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@barthbradley Fra clip distance does not appear, it shows Far clip offset... it's the same?
No sir, still no working.
Edit the in place model deck/stair and change the category to Generic Models.
I'm not sure I understand the issue then. What are you not wanting to see that is showing in the View? Those halftone elements? Where are they coming from?
It is not the far clip....what u r seeing is the projection of the family which the section is cutting
You need to use a cuttable family/category
@RDAOU Thank you very much
Hi, How did you solved the problem? I am having exact same problem with my model in place elements in my section plans. I am seeing the ones that are behing the section line
I am modeling a lot of furniture (model in place components) in this project. Any help?
