Hello all,
I am looking for some remote training on revit, I have a file that I need to edit to match a proposed idea that was done on autocad. I have very limited experience so I am looking for someone to spare a few hours to help online using screenshare etc. I am willing to pay for the training. It mainly relates so external wall elevations that are all different that need to be connected as one, so pretty sure anyone with experience could help with this.
Thank you.
@RDG122 wrote:Hello all,
I am looking for someone to spare a few hours to help .
It mainly relates so external wall elevations that are all different that need to be connected as one.
It doesn't even sound like a "few hours" of work. Can you post screenshots showing what you mean by walls "need to be connect as one"?
It would take someone who knew what they were doing a few minutes probably haha, I have sent you a message!
Looks like all you need to do is join the walls together. Use Join Geometry tool on the Modify Tab. If the Walls all have the same exterior finish material and are co-planar, Join Geometry will remove the linework between them.
When I try that I get the message "Highlighted elements are joined but do not intersect"
