Revit type image not loading itno project
ShareefAlhussain
Message 1 of 17
ShareefAlhussain
I have light fixture that i try to include it's image in a schedule, but i found that it's image does not loading into my project, and appear as none.
Accepted solutions (4)
Replies (16)
Message 2 of 17
syman2000
Try edit the family. In the family editor, add your image
Once you load the family into the project, the image will appear and it is grey out.
Message 3 of 17
ShareefAlhussain
Hi @syman2000, and thank you for your attention, i already tried that but it doesn't load!!??
Message 4 of 17
syman2000
Are you using Revit 2024? I tried this with 2022 and it seems to work fine. Try saving and renaming the family. Load the new family in and see if the image still appear.
Message 5 of 17
I don't know what the issue is on your end. Everything is peachy-keen on my end.  BTW: Images only show on Sheets.
Message 6 of 17
ShareefAlhussain
Yes @syman2000, I'm using revit 2024.1, i only faced this issue with 2 families, the others are working fine.
Message 7 of 17
Ah! I see why. The one you posted is not the one you showed in your Screenshot.
Message 8 of 17
Can you post the problem child family?
Message 9 of 17
ShareefAlhussain
Oh, my fault!, here is a copy.
Message 10 of 17
syman2000
When you load in the family, did you choose the second option? If you choose the first, it will not override the image parameter.
Message 11 of 17
Make the Family Shared and reload into Project.
Message 12 of 17
ShareefAlhussain
Yeah of course @syman2000, but also didn't work.
Message 13 of 17
ShareefAlhussain
I tried that @barthbradley , but the issue still there
Message 14 of 17
Well, it works on my end just fine.  No issues. Screenshot above proves it.  Are you sure you checked the box next to "Shared" in the Family?
Message 15 of 17
Try this one....
Message 16 of 17
ShareefAlhussain
Well ot turned out that the whole time i was trying to assign the image for another type in the family 😅, thank you guys @syman2000 @barthbradley, and thank you for your time.
Message 17 of 17
I'm not following. The Image did not load into Project until I set the Family to Shared.  That "problem" Family you posted DID NOT have Shared checked and so the Type Image was "None" in the Project -just like your Screenshot shows. The solution is to make the Family SHARED.
