Maybe I don't have enough power on my graphic acceleration, but it really annoys me when using the pan function for visual textinformation search, revit turns off all annotations while the plan is moving on the monitor... which makes it visually difficult to find errors in design using the monitor.
how to solve this problem? how to get the computer to make the image stable while the view on the monitor is moving?
Solved by SteveKStafford. Go to Solution.
This post is a more than a year old so you've probably moved on...so for future readers having a similar issue. In recent years Revit has these options (File > Options) for Hardware settings. See if turning on/off the top two items (one at a time) makes any difference.
Steve Stafford
Steve Stafford
