Revit to MS project
1 REPLY 1
2411 Views, 1 Reply
Revit to MS project
Hey there
Anyone has a solution to how to export ones revit model to MS project, for doing construction time plan?
i've been searching the web for hours, and couldnt find one good solution. a company called Bimjet made one but the last version i saw only worked for revit 2009. Some place it is mentioned that Autodesk consulting has made an add-in but i cant find that either. As of right now, when i do construction time plan, i export all my quantities from revit into a program called Sigma, which links my quantities to my library made from the danish price books, that has price and erection time for the different elements. I then export this file to MS project, which gives me all my element with dates , but i have to link everthing manually. I wanna try to keep everything within revit and thats why im looking for a solution to go dirrecty from Revit to MS project
-Ras
1 REPLY 1
boikoartem
I have published my new course on Udemy:
Microsoft Project Management in Revit with 4D Time and 5D Cost
This course “Microsoft Project management in Revit”, will present how real-life Revit projects have used the Tool Dynamo - to calculate working hours and working costs and with the help of an example, I’d like to show you how you can use project management 4D Time  and 5D Cost  in Autodesk Revit.
We will take the volume parameter of the building elements otherwise Revit-Families – then we will translate these volume parameters into time and cost.
The resulting data you can use in a variety of other programs for the control of the timing and the cost of construction. The obtained data can also be exported in another process management software Microsoft Project or other planning tools – such - scoro, asana, smartsheet, monday, hive, ganttpro or others.
Forma Design Contest
