Hi All,
I am trying to increase the effiecieny of my IFC exports and would like to use the export User Defined Parameter Sets option however the user guides I have found online refer to a file "DefaultUserDefinedParameterSets" that I can use as a basis for making my own.
For some reason this files doesn't seem to exist on my system, Is there somewhere I can download a copy ? Or am I simply missing something ?
I have attached a screen shot of the file location I was expecting to see the text file as well as an extract from the guide I was reading.
Thanks Lee
Solved by LeeUUSLM. Go to Solution.
Hey,
This may be completely off-topic, but it appears you are using an outdated IFC exporter.
Would just like to point you to the updated version here: https://sourceforge.net/projects/ifcexporter/
Depending on what Revit version you use you can find them on app store autodesk too..
Cheers, K
