Revit stops responding after opening a project
licencia_revit4
licencia_revit4
Community Visitor
Community Visitor
Hello, i'm having problems with revit crashing after opening some projects, it happens only with a few of them, I guess it depends on the size of the project since it had happened with files over 30mb. It doesn't even show a error message it just freezes the program.
Screenshot 2025-07-01 114237.pngit's not even using all the computer resources.it's not even using all the computer resources.
Any help would be appreciated.
Basam.Yousif
I couldn't tell what is causing this, without seeing the issue live. However, here is a post that I responded to last week and solved an issue that could be similar to yours, because it targets most of the troubleshooting steps that we use everyday at our support help desk and client support:
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2025-4-2-will-not-open-cloud-project-f...
mari.shimode
Hi @licencia_revit4, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
