Revit: Sheet export to DWG not maintaining view scale
Message 1 of 12
I'm trying to export a single sheet, that I have set up with views in the correct scale, to DWG. Instead of keeping one section at 1/8" the other at 3/8", and the plan at 1/8", the DWG opens with all views at 1:1 scale, and the annotation text is so large that a single number is 9' wide. What am I doing wrong? I am opening the DWG in Rhino, but isn't a DWG just vector lines?
Hi @Anonymous,
zsolt.varga has edited your subject line for clarity and search engine optimization.
Original: "Sheet export to DWG not maintaining scale"
Replies (11)
Message 2 of 12
exporting correct units?
Message 3 of 12
I checked, and the units were inches, which makes sense to me since the sheet views are set up in fractions. But then the dwg opens in feet
Message 4 of 12
Are you sure you aren't exporting Views instead of Sheets?  Does it open in Layout or Model Space?
Message 5 of 12
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @Anonymous,
What happens if you use the export setting "Export views on sheets and links as external references" ?Export_Views_on_sheets.png
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
Message 6 of 12
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @Anonymous,
I just wanted to follow up with you and see if my suggestion took care of the issue.
Please, don´t forget to use the "Accept Solution" button if it did - this way we can help other users as well.
Best regards,
Zsolt Varga
Autodesk, Inc.
Message 7 of 12
Sorry I've abandoned the topic. I'm in the middle of finals week, and I've moved past this issue by just re-scaling manually. I am interested to figure out how to accomplish this, so I will come back after finals. Thanks
Message 8 of 12
Out of curiosity; is part of your final exam suppose to demonstrate how you can export Revit to CAD at the correct scale?
Message 9 of 12
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for your feedback.
Sure - take your time and get back to us later letting us know if the suggestions helped - I will keep an eye on this thread and will continue assisting you if necessary.
Best regards,
Zsolt Varga
Autodesk, Inc.
Message 10 of 12
Hey I know it's been awhile, but I'm finally able to get back to figuring this out.
I have this setting "Export views on sheets and links as external references" checked already.
When I exported again just now it created 4 separate files, one for each of the 3 views and one of all 3. I don't remember it making more than one file when I was last trying this.
When I save this is what I have set
When I import into Rhino I have these options
This is the result
Message 11 of 12
I had some scaling issues as well.  I have found that there three instances where the units need to sync up for a 1:1 export for revit => rhino.
1) Your view scale should be at 12"=1'
2) In revit DWG export window click "Modify Export Setup"  => "Units &Coordinates Tab" make sure that one DWG unit is 1 foot.
3) When you open the project in Rhino it will prompt user to choose units, make sure both choices are in feet.
This syncing up units has given me a 1:1 DWG file that i am then able to design in back in revit and not worry about origin point.  Hope this is somewhat helpful!
Message 12 of 12
Mohamed-Nassar
check the view port scale and export setting Units
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
