Revit Conditional Formula in Schedules
Message 1 of 10
Hello all,
I'm not even sure if what I am asking is possible but here goes:
I am trying to create a formula to schedule my occupant load by using live linked areas.
So I started by creating an area table and include the associated level and area. I have then used the "comments" field to filter the schedule. My comments field will have a letter associated to indicate the type of occupancy based on our Canadian code. So in this project I have a parkade (F3), retail (E), and Lobby (D).
The next step is to set up a new formulated parameter that will tell revit if "comments" = F3, then "area"/6  and if "comments" = E, then "area"/9 and if "comments" = D, then "area"/2.
I have been messing with if conditional formulas all afternoon and I dont believe I can use a letter, correct me if im wrong? but I could change it to a number if the formula worked. ie: if "comments" = 1, then "area"/6
Hoping to take full advantage of Revit, so would be great to hear if this formula exists.
Replies (9)
Message 2 of 10
You cannot use a text field for the formula.  Entering a number in the Comments field doesn't work because it is still a text parameter.  Create a new Number or Integer parameter and use it instead.
Message 3 of 10
Okay, makes sense.
So i have created a new parameter that is under the number category called "room assembly". Can I create a new field for occupancy with a formula that says if "room assembly"=1 then D, if not F3. Just assigning a letter or letter and number to the calculated parameter?
Because youre right, after I changed my 'occupancy" to a number i was able to accomplish the area/6 formula no problem.
Cheers
Message 4 of 10
Yes you can create a calculated parameter "Occupancy" in the schedule with that formula. "Occupancy" can be a text parameter and its formula should read:
if (room assembly = 1, D, F3)
Message 5 of 10
Worth watching:
https://www.youtube.com/watch?v=tU93AbeVZZo
...FWIW: "Occupancy" already exists as a Room Parameter (Text).
Message 6 of 10
You know what is a better approach than using a formula for populating room occupancy? A key schedule.
Message 7 of 10
I'm aware that the "occupancy" already exists, and after watching the video it seems very much manual still. Having to enter values for the load factor and for the occupancy. I have attached a snip of my excel sheet that I am trying to recreate, disregard the provided columns because I still haven't determined how I will show this (probably be manual).
But essentially If I can create a formula that ties everything back to the occupancy that way when I type in the occupancy field = F3 then it will auto fill my occupant load, door width required, corridor required and so on.
I'm really close, I just can't get this formula to accept the F3, is revit not understanding because it is a letter and a number?
ToanDN, I haven't looked into Key schedules much. But maybe my next schedule will be a key schedule
Message 8 of 10
Key schedule example:
Message 9 of 10
2 issues with key schedules that I found:
- It doesnt allow me to include linked elements
- It doesnt allow me to show the area only
Message 10 of 10
You are correct, linked elements are the killing factor. But I don'y understand your other comment. Key schedules are meant for populating preset values to multiple fields by choosing a single key. If you want to show actual rooms' Area and calculate Occupant Loads you do need regular schedules.
