Revit Scaling issue on surface book
Hi Autodesk community, does anyone know why this would happen in revit on a surface book. The icons/toolbars/properties windows all look as they should, but all schedules and object snap symbols are super tiny and compressed. Please help if you have this issue or know of a fix. I have tried all different combinations of resolutions and scaling without any luck.
Chris
FYI.
Revit 2017 LT
Microsoft Surface Book
screen resolution 3000 x 2000
scaling 200%
Reduce scaling to 150%. If everything is too small then you may need to reduce the resolution as well.
I have tried all different combinations of scaling and resolution changes without noticing any change to the image that I have linked. it just makes make is bigger or smaller, the squished text always remains the same size.
Viveka_CD
Hi @Anonymous
Which version of Revit are you using?
  • I recommend that you install the updates by signing into your Autodesk desktop app
  • This scaling issue error has been addressed in the 2017.1 update. For more details see the following help topic: New in Revit 2017.1
  • Have you enabled graphics acceleration?
  • Do you have your surface book connected to an external monitor?
  • Is your graphics card updated with the latest driver from the manufacturer's website?
  • Check this link for certified/recommended hardware.
Let us know if you were able to resolve your issue.
