Revit saving , loading , sync. take 10-15 min to load
B_lionelbv2
B_lionelbv2
Hello i have issue with revit
When i try to open up the program it take around 15-30 min to open-up.
And when i open up a project it take around that same time
Saving and sync. is also slow its really difficult to do some work with that is someone has an answer to help around that would be great
Sincerely Lionel
bimscape
What are you hardware specs?
How big is the Collaborative Model?
Can you just open the Worksets you need to work on? This will help a lot, if it's a big Collaborative model)
Also close all windows before saving and pick a simple default starting View- this will help with opening times
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
B_lionelbv2
Intel Core i7-4770 CPU @3.40 Ghz 3.40Ghz
Ram 16.0 Go
Windows 7 64bits
Graphic card Nvidia Geforce GTX 1050 Ti
The file is around 89 mo
its the revit itself it can be a new project or a old one it take forever to do something
I update all hardware on the computer it did nothing so far
Sincerely Lionel Begue
bimscape
Is it only Revit that takes so long to open on that PC? Is everything else (all other software) OK?
Kind regards,
Ian
B_lionelbv2
yes
and it was fine the morning and it started on the afternoon
it's been 2 days since that
Sincerely Lionel
