Revit Render Plugin
Revit Render Plugin
FarhanUddinShaikh
Revit Render Plugin
FarhanUddinShaikh
Hi, Can anyone knows about How  many types of render plugin like Enscape easily available in Revit?
Accepted solutions (3)
ennujozlagam
@FarhanUddinShaikh hello here are some
https://www.chaosgroup.com/vray/revit
https://www.indigorenderer.com/revit
@FarhanUddinShaikh: Why do you ask? After all, this info i only a Google search away. But, comparatively, I find Encape the wicked coolest and wicked fastest of the bunch. Eye of the beholder though. I'm sure there are others that would rank it 2 or 3 on their list of favorites.
FarhanUddinShaikh
Yes there are much plugin's but i am asking for specifically concren about "Enscape" type plugin's
Viveka_CD
Hi @FarhanUddinShaikh
You can search for 'render plugins' and 'render' in the search bar at this link HERE
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Check out Lumion Pro. This is the Revit sample project which took about an hour to build the scene and the images took around 15 seconds to render.
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! Thanks for sharing.
Please check out the tutorials below for using Lumion with Revit:
LiveSync for Revit: Model synchronization
LiveSync for Revit: Camera synchronization
LiveSync for Revit: Materials synchronization
