Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
What is the best way to get the bottom railing to follow the angle of the stairs?
Post the project (RVT) here.
Maybe you don't need a rail there.
I solved it for you create ramp beneath those steps as a work around then choose pick new host those stairs
Accept my answer if it helps you
Amazing. Thank you!
Your railing is simply missing the target. Edit and adjust the sketch linework and/or change the Offset from Path.
