Can .txt shared parameter files be renamed?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
JsphH11
287 Aufrufe, 3 Antworten
Hi I want to rename the .txt file, I'm kind of afraid by doing so, all the association will be lost.
3 ANTWORTEN 3
Nachricht 2 von 4
David_W_Koch
als Antwort auf: JsphH11
Renaming the file itself will not have any effect.  Revit does not retain knowledge of the source file of a shared parameter.  All that matters is the GUID that is associated with the shared parameter.
David Koch
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 3 von 4
ennujozlagam
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-rename-a-sh...
Nachricht 4 von 4
JsphH11
als Antwort auf: David_W_Koch
Thanks yeah is that shared parameters are so "Delicate" with all their Handling rules, one might be afraid of doing so. Thanks I will rename the file as you recommended.
