Revit project performance | Open duration
!Dalton_Goodwin!
Message 1 of 15
!Dalton_Goodwin!
How many different things effect how long a project takes to open? The project I am working in isn't that large compared to other projects, yet takes a lot longer to open. The project is local, there isn't really any CAD models in it, there isn't a lot of families, or design options, or crazy parameters. The only thing I find that is different then most other Revit models is that there is a high number of links.
Any ideas?
Thanks!
Replies (14)
Message 2 of 15
RobDraw
I find it odd that you do not say this definitively like the other things.
It does take time to load links and the more complex the link, the longer it takes to load.
Rob
Message 3 of 15
!Dalton_Goodwin!
Thanks. I figured links could be the problem. If that is the case, then is there a way to reduce opening times?
There is a 2D site file CAD link. As for direct imports there is none.
Message 4 of 15
RobDraw
Clean up the links of anything that you don't need.
These files can contain a lot of stuff that may not be needed in your project.
Rob
Message 5 of 15
Maybe time to Audit and resolve Warnings.
...how big is the file?
Message 6 of 15
RobDraw
Yes, sometimes what should be considered regular file maintenance items can solve performance issues.
Rob
Message 7 of 15
!Dalton_Goodwin!
Audits, compacts, and rebuilds are done weekly through an automated system. Warnings are light. CAD file isn't anything to complicated. Nothing appears out of the ordinary compared to other projects. The number of complex links are the problem, I am pretty sure. I guess I was looking for something different or something I didn't think of.
Thanks for the help.
Message 8 of 15
!Dalton_Goodwin!
The file is about 198mb.
Message 9 of 15
RobDraw
Do the links have any links or XREFs that aren't being found?
Rob
Message 10 of 15
That's nothing these days.  The sluggishness you're experiencing could also be due to a "bad" family. I've introduced families into projects that have acted like fricking boat anchors in the project.  Maybe that's where the problem lies.  Another thing, CAD in families will impact performance -- especially if its been exploded.  Maybe imported CAD used as a reference to create the Revit Family still remain in the Family.
Message 11 of 15
That's it?   I've had templates that size.
I'd be questioning your workstation specs and network connection if you are having that many issues.
Message 12 of 15
No linked IFC files? They are rebuilt by Revit on open (if have changed since last use) and can take a long time.
Message 13 of 15
!Dalton_Goodwin!
That is a good idea Ill try a family export of everything and see if there is any crazy families. Thanks
Message 14 of 15
!Dalton_Goodwin!
If is a connection issue. Then it is only this model. As for the workstation, that is fine, it is a pretty high end computer.
Message 15 of 15
sdbrownBECK
Its most likely the time it takes to load all the links.  Put your links on a workset for each link, IE  Link-MECH, Link-Struct, etc. then when you open the model  use the "selective open" feature (little arrow next to the open button). chose "select" instead of all.  then your worksets dialog box will pop up and you can close all your link worksets.  then open the project and it should open quickly.  then when you need to see the links open the worksets as needed.
