Revit not printing some text and images properly to PDF
Message 1 of 25
Revit is not properly printing some text and images to ANY PDF printing software. Text spacing is off and sometimes overlapping. Images may show up on some sheets but not others. Some text is completely missing. Tried everything related to settings. Any ideas?
Replies (24)
Message 2 of 25
Message 3 of 25
Thank you - Currently using Revit 2020 and none of these items were the cause.
Message 4 of 25
Message 5 of 25
No such luck, my team has tried the applicable options.
Message 6 of 25
You're not making this easy. You say you've "tried everything". Have you tried printing from other applications?
Message 7 of 25
syman2000
What is your PDF driver (Adobe, Bluebeam, CutePDF) and the DPI output resolution?
Message 8 of 25
The only issue seems to be printing from Revit - we have tried printing to Bluebeam, Cute PDF, Microsoft PDF, Adobe PDF, and PDFforge, and all have had the same output.
DPI: 600
We have tried Microsoft Updates, Drivers, Plug ins, Addons, deleting temp files, .net framework repairs, with no luck.
Message 9 of 25
syman2000
Upload the file so we can take a look.
Message 10 of 25
I'm wondering if an Add-In is causing the issues?   Disable Add-ins temporarily and see if you can Print.
How to disable add-ins for Revit | Revit Products | Autodesk Knowledge Network
Message 11 of 25
Here is the current file - It has happened to every one I open and test print from.
Message 12 of 25
syman2000
Seems like IC-300 having issue with the image showing up. For text I don't have any issue.
Message 13 of 25
text issues were mostly on dimensions - it may not have that instance in this particular file. I wonder what would cause both problems.
Message 14 of 25
Prints beautifully on my end.
Message 15 of 25
john_nordmark1
We started to have the same problem the day before yesterday. The problem appears when printing with Bluebeam and PDFCreator but not with Adobe PDF. We use PDFCreator as standard PDF printer from Revit because it works best with our batch printing tool. First we tried to fix it the screen resolution and screen scaling but it didn't help this time. Our IT-department sent out some security patches for windows and I'm wondering if it is connected. @Anonymous have you installed security patches recently?
Message 16 of 25
Turned out to be a Windows Update that caused all the issues. We were able to resolve this by un-installing it.
Message 17 of 25
ktnelson
Which update did you uninstall?
Message 18 of 25
john_nordmark1
It is KB5000802 or KB5000808, depending on witch version of Windows you are running, that are causing the problem.
Message 19 of 25
Message 20 of 25
junEU746
Community Visitor
Community Visitor
i have the same issue after i update my windows... but my colleagues didnt update their windows, so they dont have such problem.
