Group member had to be moved to project
1 ANTWORT 1
Nachricht 1 von 2
hunterAZR7A
1353 Aufrufe, 1 Antwort
Hi all, I'm inserting a 3D closet family inside our unit plans, which is are groups of walls and families dispersed throughout the model. In most units, this error doesn't happen. However, it does happen in some. I'm not sure what's causing the problem, and I don't want this to happen to other families. If it's a glitch, that's no issue, since we just let the families become ungrouped and just keep them in place.
Tags (3)
Beschriftungen (2)
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: hunterAZR7A
I assume you are using linebase family. Group don't like linebase family. It will want to detach itself from the group and create duplicate. Your best bet is to replace them with normal family with instance stretch.
